AutoCAD text editing
when i click on the text option the text box appearing but unable to find the end of text box
DavidDillonJr
@Anonymous Just type something, click outside the text box to close it. z enter a enter. Click the text and adjust the box smaller, it make take a time or two to get it to the size you need.
If I recall correctly are you working in a viewport, if so you may want to work in model space for the text.
David Dillon
dmfrazier
In addition to other advice, you should be able to zoom out while you are editing the text/mtext.
deke01
If you still can't see the end of the text lines (the grips) you can change the width in the properties palette.
Look into the dtexted variable I think. Set it to your needs
imadHabash
i suggest to do the follow :
  •  Select you Mtext .
  • Ctrl+1 to activate properties dialog .
  • go to Columns (Text tab ) and select it >> Column Settings >> No columns ( this step to activate Defined Width.
  • get back for properties dialog >> Defined Width >> insert a proper small value .
  • Now .. you will find that your Mtext box reduced following the previous modified value .
Imad Habash
Thomas_Stuehle
Hello @Anonymous
Welcome to the AutoCAD forum.
Did the post above help you and answered your question?
If yes, feel free to click on the button "Mark as Solution". Thus also other users can benefit from the information. In case you still need help please feel free to provide an update here so we as Community know how we can help you best moving forward.
Best regards,
Thomas
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Thomas Stühle
Technical Support Specialist
