AutoCAD stuck on loading screen
I have installed AutoCAD for students and the problem is that the loading screen never finishes loading.
I tryed reinstalling it, redownloading it.
Also I am always getting 2 errors at the installing process.
What should I do?
P.S I made a screenshots of my errors.
Alfred.NESWADBA
it looks like you have
  • not enough permissions
  • the installation was blocked from an antivirus or other defending software
  • your registry has defects
As can be seen in >>>that article<<< that's not just an Autodesk product based exception.
I would run diagnostic sofware to see if your Windows is ok, then do a complete uninstall of the current installation (>>>details<<<), create a new user with full admin permissions, turn off antivirus, redownload the installation package (remove the existing one first and if there exists anything in the C:\Autodesk folder delete that (or move that to any other position)) and after that start the installation with admin permissions.
Good luck, - alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Thank you, I will try
