AutoCAD Forum
Autocad slow on battery
4 REPLIES 4
1397 Views, 4 Replies
When i plug my laptop (dell xps 9570) its running autocad smooth but when im running on battery it becomes very laggy
4 REPLIES 4
RobDraw
Check the power settings on the laptop. Set it for performance (or something similar).
Rob
s.borello
I bet your machine is configured to not be as fast when not plugged in... have you checked your power settings?
in reply to: s.borello
i've checked it and it is set to performance
Alfred.NESWADBA
You have checked this while the laptop was not connected to power?
Make one additional test, one time the laptop plugged in, one time not, in each state do the following steps:
  • start AutoCAD with an empty drawing
  • start command _GRAPHICSCONFIG
  • create a screenshot and show it here.
Reason: on systems with 2 graphic cards AutoCAD might not see the correct GPU when in unplugged mode.
Also important: besides of the laptop performance settings, some graphic cards have their own settings, so verify that too. Even if the CPU is set to high performance in unplugged more, the GPU might run in power saving mode.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Forma Design Contest
