AutoCAD Forum
Autocad sketch to Inventor
5 REPLIES 5
380 Views, 5 Replies
Its been 2 days that I'm struggling with this.
I need to send a sketch from Autocad to Inventor, and extrude it.
But when I send it, It goes with A LOT of splines/vertex lines and the extrusion command from inventor can't read it.
It shows as a broken profile, but it's not broken, it's reading the wrong lines.
how can i fix that? i tried to use the sketch doctor, tried to export in another format, tried to erase the vertex lines, nothing is working.
I need to extrude what is showing in blue (this is just a part of the drawing, its much more than that)
Labels (1)
5 REPLIES 5
Patchy
Attach your .dwg and let's see what you got.
pendean
"sketch" means what to us without access to your DWG file? What are those object types in AutoCAD, you used what command to create that shape?
It looks like you used exactly what INVENTOR told you they are, Splines.
What did the folks at the INVENTOR forum offer up as a fix?
done 😉
in reply to: pendean
I posted the .dwg attached.
The people from the inventor forum didnt answer yet.
Patchy
Those splines aren't connected so you can't extrude, convert them to polylines then use Boundary, then extrude.
My Autocad is too old to use splinedit,  you can do it with newer Autocad.
AutoCAD Inside the Factory
