Why my AutoCad 2022 is showing units mm and dimensions are like exact. i have reinstalled it and its coming like that.How can i reset settings of Autocad to get back into inches and all the stuff.
what you see in Unit dialog is used for scaling if you are using command insert or xref,
nothing to do with dimensions.
What you after is the DIMSTYLE,
there you can find all settings for dimension and the dimension text.
Sebastian
When creating a new drawing, start from acad.dwt instead of acadiso.dwt template.
The first one is imperial based, the second one is metric based.
For already created drawings, use the DWGUNITS command to swap between systems of measurement:
