Hellos ,
I converted the pdf to rotate an angle of view in Autocad. There is a image problem. problem solve convert to PDF:
Don't be straight instead of angle.
thank yours
ATTACHED DOWNLOAD
[The subject line of this post has been edited for clarity by cheryl.buck]
Thank you for posting the video and images. I see that you are exporting the content to a PDF using the DWG to PDF driver. Do you get the same results if you use the PLOT command and select one of the AutoCAD drivers, such as AutoCAD PDF (General Documentation)?
I know some PDF viewers handle images differently, but cannot tell which PDF viewer you are using, Does the resulting PDF look any different when you view it in a generic viewer like Chrome?
All the best,
I tried above. they fail.
1- ctrl+p and command : plot
2- Autocad > export > pdf
