AutoCAD Render Image on Side of Model
J-Money_Undef33ted
J-Money_Undef33ted
Hello there,
I am trying to render a drawing that has a company logo JPG on the side of a shipping container, I have assigned a material to the shipping container but not to the JPG.
When i print the view port realistic, the image of the company shows up but when i render the viewport, the Company Logo image is nowhere to be seen and all i see is a plain Shipping container.
Any Suggestions?
I highly recommend to use Autodesk Showcase for rendering AutoCAD models. However, you will get amazing results if you use an advanced software such as 3Ds Max.
J-Money_Undef33ted
Thanks for the advice but an answer to the question would have been a bit more helpful.
pendean
Community Legend
Community Legend
If you want help then post the DWG file with the problem so someone can see what your actual issue is, your description alone is not sufficient for any precise diagnosis.
Alfred.NESWADBA
Rendering needs a material that uses this logo as texture map inside the material (and placement using texture mapping coordinates on the object).
Please find info about mapping >>>here<<<
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
