Text insertion point problem
Message 1 of 21
Text insertion point problem. The cursor blinker has a triangle that makes editing the text all wrong
Replies (20)
Message 2 of 21
imadHabash
does this happened in general or just in a certain mtext ? if in a certain one please could you attache it here ?
Imad Habash
Message 3 of 21
Only in some of them. If I copy the text to another application and copy it back its gone. I have attached a dwg
Message 4 of 21
imadHabash
Yes .. i noticed that also !! but if you select all the text ( Ctrl+A ) then right click and select Remove Formatting , any changes ? it's work with me .
Imad Habash
Message 5 of 21
It didnt work
Message 6 of 21
imadHabash
would you please open and test attached file ? ( be careful i add numbers  )
Imad Habash
Message 7 of 21
the problems not there anymore. Its odd that I cant fix my drawing. I dont know what it is
Message 8 of 21
imadHabash
Cool ... make sure that you select all the mtext and remove formatting .
Imad Habash
Message 9 of 21
It doesnt fix the problem in my drawing
Message 10 of 21
imadHabash
BTW ... as additional action , make sure that your AutoCAD version is up to date .  >> Click <<
Imad Habash
Message 11 of 21
vinodkl
forma.pngHi,
Edit the text and select all and then change the font to a different one like arial narrrow and then back to Arial. See if this fixes your problem.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 12 of 21
imadHabash
when you remove formatting , your text respond or not ?
Imad Habash
Message 13 of 21
Changing the font works. But I cant go around like 50 different text changing the font around. Its going to take me a while to fix this then if theres no other options
Message 14 of 21
nothing happens when i format it. It just stays exactly the same
Message 15 of 21
imadHabash
 i'll prepare a short screencast for you .
Imad Habash
Message 16 of 21
vinodkl
In that case try this lisp. (check only the font when you run the lisp)
Just incase if your not sure how to load load lisp click here
Message 17 of 21
imadHabash
hope it's give a hint ..
https://autode.sk/2A6UOTl
Imad Habash
Message 18 of 21
OMG thats way to complicated
Message 19 of 21
I have tried this it doesnt work
Message 20 of 21
vinodkl
Its not that complicated.
Type in the command APPLOAD and browse the .lsp which I had attached and then click on load(upon loading you can see a message at the bottom saying "successfully loaded"). close the dialog box
Now type in the STRIPMTEXT and select all the text and press enter then check mark only font and click on ok that's it.
