Title block scale issue
Hello ,
When I create a Title block of A4 AND SET paper setup as A4 , but some time insertion of title block is bigger then paper set up? Is that something in unit conversion or?
Thank you
imadHabash
would you check Insertion Scale from UNITS command ?
Imad Habash
Please see the attached image
imadHabash
i wish you attache the CAD file itself , the image didn't help !?
if you mean that you want to match the white area in paper space layout to your A4 block then you have to make a proper page setup and set it current  [ PAGESETUP command] , have you ?
Imad Habash
ChicagoLooper
Are you inserting your A4 titleblock into an imperial template? You need to insert A4 titleblock into metric.
Chicagolooper
