AutoCAD - Problems deleting layers
emma.odering
Message 1 of 9
emma.odering
Hi There.
I am trying to delete some layers but for example layer 2d shows it has the toilet block on it. I've tried going into block editor & it shows it's on layer SV_PL_FX which is correct. So how can it be on layer 2d? I want to delete layer 2d as it must have been imported with the block. Thanks.
[ The subject line of this post has been edited to include the product name by @handjonathan ]
Replies (8)
Message 2 of 9
Washingtonn
Message 3 of 9
emma.odering
Thanks very much. I did that & exploded, then put all on the correct layer. But it still won't let me delete the layer 2d. Any ideas?
Message 4 of 9
Washingtonn
Message 5 of 9
emma.odering
Thanks. Then I get the msg 'Purge command not allowed in block editor''
Message 6 of 9
RobDraw
Don't do it in the block editor.
Rob
Message 7 of 9
RobDraw
Instead of exploding, redefine the block. Save the block. Save again, then purge the drawing.
Rob
Message 8 of 9
emma.odering
Got it. Thankyou!
Message 9 of 9
handjonathan
Hi @emma.odering
Thanks a lot for posting your question to the forums!   Has the solutions suggested by @RobDraw & @Washingtonn  helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
