AutoCAD - Problem With Copy Base and Copy Commands
awg7340
awg7340
Hi
I am having problem with the copybase command to another drawing. I currently have a few boreholes layout which i want to transfer to a site layout drawing. When i select the objects and use copybase command with assertion point (0,0), nothing happened when i paste the borehole drawing to site layout drawing.
The other day, I also had an issue with the copy command. When I first copied and paste the object, it was fine. But when i copy and paste the second object, the first object keep appearing as paste object. In the end i had to cut and paste the second object.
Does anyone has any solution for this? Thanks. Just to let you know, I am a  beginner in AUTOCAD.
[ The subject line of this post has been edited for clarity by @handjonathan Original: Problem With Copy Base and Copy Commands ]
ChicagoLooper
Hello @awg7340
Please describe your workflow when you COPY?
Do you select the object(s)=>Right click=>Copy with Base Point=>0,0
Image-1Image-1
Be sure to review the command line. It displays the coordinates of your basepoint and the number of objects you have selected.
Image-2Image-2
Chicagolooper
cadffm
..nothing happens
for 99% it works, but the user expected another size or didn't realize that layers are off or freezed or similar things.
1% also possible that there is a problem, but it is pointless to talk about it if there is no concrete reproducible example.
..paste old clip
very often users telling that if they trying to copy&paste Blockreferences to another file, what is explainable often.
But it can be an clipboard problem too. Computer re-start, try it again.
and if you have currently reproduceable problems: You're welcome, share your files, screenhsots and screencast -  all what can help to see and understand what you see and what happens on your side.
Sebastian
imadHabash
I suggest to check your layers status in second drawing. maybe the objects are copied but the layer turned off or freezed?
Imad Habash
