AutoCAD - Problem With Copy Base and Copy Commands
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi
I am having problem with the copybase command to another drawing. I currently have a few boreholes layout which i want to transfer to a site layout drawing. When i select the objects and use copybase command with assertion point (0,0), nothing happened when i paste the borehole drawing to site layout drawing.
The other day, I also had an issue with the copy command. When I first copied and paste the object, it was fine. But when i copy and paste the second object, the first object keep appearing as paste object. In the end i had to cut and paste the second object.
Does anyone has any solution for this? Thanks. Just to let you know, I am a beginner in AUTOCAD.
[ The subject line of this post has been edited for clarity by @handjonathan Original: Problem With Copy Base and Copy Commands ]
