Dear All:
I got a probelm below:
When i open a cad file, a massage box pop out with " OK " massage and i cant remove it. Also sometimes it pop a massage load acad.isp
Please teach me how to remove it as it will pop out each file when i use the publish function.
Thanks a lot!!!
Dear All:
Thanks a lot!!!
i suggest to select one of those options that meet your need then check the small box in the same dialog ( see below image ) . now reopen your file and see if any changes.
Imad Habash
Imad Habash
Hi Imad Habash,
Thank you for the reply. I click the small box and reopen the file but that "ok" massage box still pop out, further detail as below:
-This massage box only happen when the first time i open autocad file , it will not show when i open the second file.
-when i use publish function , say publish 20nos of drawings, that "ok" will pop out 20 times and i hv to click 20times of it to keep the publish keep going.
I am worry if this is a virus, when i use other computer open it, the massage box pop, and it make the other project's file cause the same problem(the new computer didt show the massage box before i open the infected file).
Thank you!
Johnny
Hi Imad Habash,
Thank you!
Johnny
It does sound like some kind of virus using Lisp. You could try searching in your computer for all instances of acad.lsp and temporarily rename the ones that are found to something else like noacad.lsp and see if the Ok message disappears.
Area Object Link |
Attribute Modifier |
Dwg Setup |
Feet-Inch Calculator
Layer Apps |
List on Steroids |
VP Zoom Scales |
Exchange App Store
Area Object Link |
Dwg Setup |
Layer Apps |
List on Steroids |
VP Zoom Scales |
Exchange App Store
