AutoCAD - Polygon split
sergiowaitforit
Observer Observer
Message 1 of 10
sergiowaitforit
Observer
Observer
Hi sirs/madames ,
Anyone knows how to split some polygons that seem to be created under the same polyline?
I have world map in .dwg but I would like to remove the small islands to print and cut it into a wood panel.
Here there is an example:
Thank you!
[ The subject line of this post has been edited for clarity by @handjonathan Original: Polygon split ]
Replies (9)
Message 2 of 10
cadffm
a polyline is ONE object, so whatever your picture shows, it isn't just a normal polyline with usual properties .
Select the object, open your properties palette [CTRL]+[1]
Check out the Object type (listed first on top of the palette)
Looks like a HATCH or MPolygon.
You are working with AutoCAD?
Sebastian
Message 3 of 10
pendean
Community Legend
Community Legend
PROPERTIES command says what about what you selected at the very top? Show us please, "polygon" is too generic a term for what you screenshot here.
Message 4 of 10
ВeekeeCZ
Use the SEPARATES HATCHES option from the Hatch ribbon
Message 5 of 10
sergiowaitforit
Observer
Observer
Hi again,
Thank you for your quick answers sirs.
Yes, it is an MPolygon. Excuse my mistake.
Message 6 of 10
Kent1Cooper
"Splitting" and "removing" are very different.  Post a small drawing file, clearly marking what you want to split [and what that means], what you want to remove, and how the two relate to each other.
Kent Cooper, AIA
Message 7 of 10
pendean
Community Legend
Community Legend
@sergiowaitforit Are you using MAP3D or Civl3D? You are in the wrong forum for both of those software and editing that object type.
Message 8 of 10
sergiowaitforit
Observer
Observer
I would like to delete these islands for example:
I am using AutoCAD 2019.
Message 9 of 10
Kent1Cooper
I don't have the software overlay to work with MPolygons [see Message 7], but if they're like Hatches as implied by other replies, does it work to draw a big Circle around those islands, and use it as a cutting boundary in a TRIM command?
Kent Cooper, AIA
Message 10 of 10
cadffm
Select your mpoly,
use EXPLODE command
and if you like to have the filling back, create new hatchs for it:
command Hatch
The HatchEditor tab is current now,
entlarge the panel "Options"  and make sure your option "separate hatchs" is ON.
Object<Select> option
and if Acad ask for objects, type in:
P<followed by enter><followed by enter>
Sebastian
