AutoCAD 2023 - Command string not working on all computers ^C^C_start
jdrury1
Message 1 of 31
jdrury1
We created a tool pallet that enables you to open our criteria for drawings.  The Command string works on some computers but not all.  Any suggestions?  AutoCAD 2023.
^C^C_start "explorer" "C:/MARTA-Tools/Toolpalette/Documents/CFD.pdf";
[ The subject line of this post has been edited for clarity by @handjonathan Original: Command string not working on all computers ^C^C_start ]
Replies (30)
Message 2 of 31
pendean
Community Legend
Community Legend
what does "not working" for some computers mean exactly please? Elaborate please, for example your file pathing is very specific for one single computer and one folder on a C-drive, so access to many others computers would be a challenge.
Message 3 of 31
jdrury1
The file paths are the same on both computers as are the file names.  When we click on the icon in the tool pallet, the PDF does not open.  The command line states unknown command "PDF""
Message 4 of 31
paullimapa
On the computers that don’t work do they have an app that is associated to open a pdf file?
Paul Li
IT Specialist
@The Office
Message 5 of 31
cadffm
I have to guess, but:
>>"The command line states unknown command "PDF"" "
Are you sure that's all?
Run the macro and press [F2], read all line starting from "Command: _start" to the end..
>>"AutoCAD 2023."
For me it sounds the workstation in question don't use AutoCAD 2023.
Are you sure it is not AutoCAD LT?
Sebastian
Message 6 of 31
jdrury1
I'm not sure what you mean by app. Do you mean Adobe or Bluebeam? If so, yes to both.  Adobe is set at the default.
Message 7 of 31
jdrury1
It is 100% 2023, it was installed a month ago.
Here is the log.
Command: "C:/MARTA-Tools/Toolpalette/Documents/CFD.pdf"
Unknown command "PDF"".  Press F1 for help.
Command:
Command:
Command: _start Unknown command "START".  Press F1 for help.
Command: "explorer" Unknown command ""EXPLORER"".  Press F1 for help.
Command:
Command:
Message 8 of 31
paullimapa
Is it possible hat not all computers have the same folder location or file name where the pdf is stored
Paul Li
IT Specialist
@The Office
Message 9 of 31
cadffm
@paullimapa  the command START is unknown, so it has nothing to do with the path.
@jdrury1 2023 or 2015, the question is: AutoCAD or AutoCAD LT
Sebastian
Message 10 of 31
jdrury1
AutoCAD not LT
Message 11 of 31
paullimapa
Could Start have been undefined?
try typing it at command prompt
precede command with a period:
_.Start
Paul Li
IT Specialist
@The Office
Message 12 of 31
pendean
Community Legend
Community Legend
@jdrury1 wrote:
Command:
That error message means that command is disabled: it means nothing else. You need to find out why.
Walk over to one of those PCs, start AutoCAD, at the commandline type .START (there is a period in the name) then hit <enter>. What happens? Also check ABOUT command for AutoCAD vs LT vs OEM version running on that workstation, and if any addons may be locking out .START command.
TIA
Message 13 of 31
jdrury1
It does not allow _start.  It automatically changes to _Startup
Message 14 of 31
paullimapa
since you're using AutoCAD on all stations try this lisp code:
^C^C(startapp "explorer" "C:/MARTA-Tools/Toolpalette/Documents/CFD.pdf")
Paul Li
IT Specialist
@The Office
Message 15 of 31
jdrury1
.start automatically changes to startup.
Message 16 of 31
paullimapa
try this at command prompt:
REDEFINE
START
then enter START again
Paul Li
IT Specialist
@The Office
Message 17 of 31
jdrury1
Yeah, it is apparent it does not like start.
It automatically changed startapp to startup when we ran your lisp.
Message 18 of 31
jdrury1
REDEFINE
START
We get unknow command name
Message 19 of 31
paullimapa
wow...are you sure you're running AutoCAD?
Paul Li
IT Specialist
@The Office
Message 20 of 31
jdrury1
lol, yes.  I'm not a guru but I'm sure it's AutoCAD.   Same copy is on my machine, and it works great.
