Autocad on surface pro 7
Message 1 of 10
hi, guys, does a surface pro 7 intel i5 (1.1 Ghz), 8 gb of ram run autocad well? I need only 2d
Replies (9)
Message 2 of 10
Alfred.NESWADBA
you can install a trial and see if your type of drawings work well.
1.1 GHz is much lower than the system requirements are shows as minimum requirement (2.5GHz) >>>click<<<.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 3 of 10
pendean
Community Legend
Community Legend
That configuration also comes with a very itty-bitty harddrive more often than not: no need to cripple yourself before you even started using it.
Message 4 of 10
So it's not worth it? Space isn't a problem for me
Message 5 of 10
pendean
Community Legend
Community Legend
The one you are inquiring about is underpowered.
The i7 versions are more suitable for 2D production work: unless you're an "executive" that spend more time showing off powerpoints and spreadsheets all day 🙂
Message 6 of 10
Hope u can help me. 😁 I have seen many of  your reply to posts and u seem supper knowledgeable in reference to computer software and my specific topic of an CAD program working on a surface..
I UNFORTUNATELY got a Surface PRO X 😓 and just saw several of your comments that state it doesn't support that. The lady at BEST BUY said it did. 😡
So my question is which Surface will work pls. I use the CADlink for Torchmate. THANKS IN ADVANCE!!!!!
Message 8 of 10
thanks !!!!!
Message 9 of 10
ndiaz53X749
Observer
Observer
Hi! I've also seen a bunch of your comments!
I'm also asking about the Surface Pro X but the newer version (2022), is it still the same thing where it doesn't support Autocad? I have a Macbook M2 but as you know AutoCAD on a Macbook is different than on Windows so I want to to trade for a Windows computer. The person who has the Surface Pro X was able to download AutoCAD and launch it but I haven't tried to use it so I don't know how it will work. I want to be well informed before I trade it!
Thank you so much
Message 10 of 10
pendean
Community Legend
Community Legend
Thank you so much
As long as the device you want to get is not ARM-processor based, AutoCAD for Windows will run on full 64bit WindowsOS capable hardware
