AutoCAD not opening
AutoCAD not opening
Message 1 of 20
AutoCAD not opening
AutoCAD 2016 Student Version lately stopped working, when I open the program the "autodesk customer involvement program" window pops-up and AutoCAD just stands still nothing is clickable! so I uninstalled this version and tried to install AutoCAD 2017 Student Version also, but when I try to open it, it just starts loading and a message pops-up saying that AutoCAD 2017 is not working, and it closes automatically... So again I downloaded AutoCAD 2016 Student Version and the same first issue happened again!
Is there a way to solve this issue please?
Replies (19)
Message 2 of 20
Sofia.Xanthopoulou
Hi @Anonymous,
and welcome to the forum.
You say that the program worked and now it is not? Have you tried to log in as a different user and start the program?
Any difference?
If so, your profile is damaged and you have to setup a new user.
Please report back to me.
Thank you
Message 3 of 20
Hi @Sofia.Xanthopoulou
Yes it was working perfectly few days ago untill it started showing license errors! I have an educational version so I ignored these errors!
I logged in using a different account and downloaded AutoCAD 2015 Student version, but still not working!
Message 4 of 20
Alfred.NESWADBA
Just a guess: a few days ago ... until your Windows was updated to release 10?
...or other updates/software packages/drivers where installed or a registry cleaner was active?
What happened on your system between "a few days ago" and today?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 5 of 20
Hi @Alfred.NESWADBA
No I already had windows 10 for a month or two... and I didn't update anything! 😕 It just started showing the error that the product is not properly activated, and later it stopped working!
Now I tried to open AutoCAD 2015 and it's showing another error!
Message 6 of 20
Alfred.NESWADBA
well, 2015 is not really ready for Windows 10, you might try to install the Windows hotfix as described >>>here<<<.
To your steps.
When 2016 stopped you tried to reinstall it, then you installed 2017, then again you tried 2016 installation ...
My feeling is your system is not really in a stable situation.
I would uninstall all AutoCAD releases (using Autodesk Uninstaller or following exactly(!) >>>that workflow<<<.
Then make your decission if you want to run 2016 or 2017, download the installation files from Autodesk Virtual Agent >>>there<<< and follow the instructions for how to install software (login as admin, turn off antivirus software, turn off firewall)
Good luck, alfred -
Alfred NESWADBA
Message 7 of 20
I followed the steps... but still the problem isn't solved! I am starting to loose hope actually :'D
these are the errors that show up!
Message 8 of 20
Alfred.NESWADBA
Screenshot "07 issue" shows me, that some step(s) were not done correctly, otherwise the installer would not find a newer version of AutoCAD.
That's why I wrote "exactly" to follow the steps.
Without a clean system it does not make sense to try the installer again and again, first your workstation has to be free of every single part of prev. AutoCAD installation.
Screenshot "09 issue" shows, that there are troubles with your graphic card (which one is it, in case you do have multiple GPU's built in let us know both).
- alfred -
Alfred NESWADBA
Message 9 of 20
Sofia.Xanthopoulou
Hi @Anonymous,
in which language is your OS?
Regards
Message 10 of 20
Yes, I found what was I doing wrong... this time I did follow the steps and the "newer version is already installed" message did not show up.
But still after installation, I disabled my internet connection then launched the application, but it freezes!
I attached a picture of the graphics card information
Message 11 of 20
I use English US
Message 12 of 20
Alfred.NESWADBA
Great, so installation seems to be finished successfully!
Look to the manual activation >>>click<<< as your first screenshot shows that this hangs.
Also worth to try: create a new user, give that user admin permissions, login with that user account and start AutoCAD.
Good luck, - alfred -
Alfred NESWADBA
Message 13 of 20
Alfred.NESWADBA
just to make sure, this is the part of your screenshot "14 issue"
For me that looks like either you are working in a virtual system or via a remote system or you have not installed your graphic card driver.
"Microsoft Basic Display Adapter" is not really a graphic card driver, it's just an emulation for the real gc as long as the correct driver is not installed. And that can be your source of this (and more) problem(s).
- alfred -
Alfred NESWADBA
Message 14 of 20
@Alfred.NESWADBA @Sofia.Xanthopoulou Not all heroes wear capes :'D Thank You... AutoCAD works perfectly now 😄
Sorry for any inconvenience 😄 thank you again
Message 15 of 20
how do you set up a new user? Don't want to mess up my desktop which is working .
@Sofia.Xanthopoulou wrote:
Hi @Anonymous,
Any difference?
Thank you
Message 16 of 20
Sofia.Xanthopoulou
Hi @Anonymous,
I have found some easy steps for Windows 7 and Windows 10 (please don't take the dummies personally Smiley Wink) for you.
I hope that helps.
Regards
Message 17 of 20
I have windows 8.1, 64 bit. Still have no clue what problem is. Both
versions working on my desktop.
Thanks ,
Don B Hill , AIA
@Anonymous,
personal data erased by Sofia Xanthopoulou
Message 18 of 20
Sofia.Xanthopoulou
Hi @Anonymous,
are we still talking about AutoCAD not opening or creating a window user? Please be more specific.
In order to make your post more apparent for all readers, feel free to start a new Topic with your personal question.
Message 19 of 20
Alfred.NESWADBA
What versions are you speaking about, seems like you have 2, but which ones?
>> Both versions working on my desktop.
If they are working, what is the issue then?
- alfred -
Alfred NESWADBA
Message 20 of 20
When I click on either icon to open Autocad, I get message that states
"autocad has stopped working". Then I get pop up box to send error report.
Did not have this trouble last time I opened software(in early summer). Just
two weeks ago and forward.
Thanks ,
Don B Hill , AIA
DON B HILL ARCHITECT
3500 S. FM 14
Hawkins , Texas 75765
903-857-2001
[email protected]
903-245-7650 CELL
