I was having an issue with AutoCAD crashing every time my laptop woke after sleep. I discovered this was due to my system switching from the high-performance nvidia graphics card to an integrated Intel one to save power during sleep. After manually choosing the nvidia processor to handle all AutoCAD tasks, I was still experiencing the same issue. As a final effort, I went to control panel>device manager>display adapters and disabled the Intel graphics card. Since then, I have not been able to get AutoCAD to display properly.
I initially got a warning from CAD saying that it required a certain screen resolution to run, despite the fact that my resolution is higher (3840x2160). I clicked OK and it runs anyway, and all the application menus display correctly, but the .dwgs I open are crisscrossed with random lines. I can't select these ancillary lines, and they change location and orientation when I zoom in. It is very strange and frustrating.
I have tried changing the text scaling in my system settings from 300%(recommended) to 250 or 200, but it just makes the text illegibly small and the random linework still obscures my drawings. See screenshot.
I have found that just as a general rule, it is best to close (not minimize) all files and applications before putting Windows into sleep mode. I have seen several issues with programs (and hardware when programs immediately place things like graphics or CPU under load upon waking) not "waking up in a good mood". If all you need to do is simply close the lid on your notebook and carry it from point A to B, in power options there should be a setting to "do nothing" when closing the lid. I use this option daily, as my work-at-home setup has 2 large screens, and notebook sits too far away for the screen to be of any use, so I close the lid and just run with 2 externals. If you don't see this option in your current power plan, try selecting a different plan.
Thanks, Dan.
Per your suggestion, I changed my power/sleep settings to "do nothing" when I close the lid. So far no problems, except one time it actually did sleep because it ran out of power. An imperfect solution, but an improvement.
In troubleshooting an unrelated problem, I found a different (imperfect) solution to avoid AutoCAD crashing upon waking from sleep. Turning hardware acceleration OFF made the problem go away, but performance was horrible. The cursor lagged and flickered so much that I really couldn't work effectively.
