AutoCAD mtext list formatting question
htrautman
htrautman
I am trying to create lists in AutoCAD 2021 using mtext with a format similar to:
1. Level 1
     A. Level 2
           1. Level 3
                a. Level 4
However, the only way I can get the lists to format is:
1. Level 1
     A. Level 2
1. Level 1
Is it possible to format lists like in the first example using mtext?
Thank you.
dbroad
Not as far as I know with mtext.  If you have a lot of multilevel lists, you should use a word process and link the documents or cut and paste as AutoCAD entities.  AutoCAD isn't a word processor.
Architect, Registered NC, VA, SC, & GA.
devitg
@htrautman  some like it , see at the right.
Mtext is some like a word processor .
You have the OFF the numbering , or better do not follow the number or letter by a point    .
