AutoCAD Forum
[Autocad LT] Tool pallete block
2 REPLIES 2
231 Views, 2 Replies
I have a question about the a block in my tool palette.
I have a drawing with a xref in it.
I want to add that drawing to my tool palette.
But i want that when i add that drawing it will be a block.
I have found the option in properties, you can choose between block and xref.
But when i choose block, the drawing is a block, but the xref in it still is a xref and not a block.
Is there a way so that xref will be a block to.
I hope my explanation is good enough.
Greets,
Tom Roelofs
2 REPLIES 2
pendean
Bind the xref in the file if you want it to be a block: otherwise you are telling AutoCAd to keep it as an xref and it does what you asked.
in reply to: pendean
I have thought of that but that is a extra handling.
You have to open the block and then bind de xref.
I there no way that it will import as a block in a block,
and not as a xref?
AutoCAD Inside the Factory
