AutoCAD - Layout Tab Hover Preview
jdfnnl
jdfnnl
Is it possible to turn off the layout tab preview? I never use this visual and wish switching sheets were more snappy. Alternatively, is there hotkeys (aside from Ctrl+PgUp/PgDn) to jump to a certain tab?
[ The subject line of this post has been edited for clarity by @handjonathan Original: Layout Tab Hover Preview ]
imadHabash
I'm afraid that it's not applicable!!
You may try a command called QVLAYOUT that allows you to preview all the layouts with a line of thumbnails at the bottom of the screen so you can visually select to which one you want to jump to. You can even change the size of the thumbnails with the usual CTRL+Mousewheel .
Imad Habash
ВeekeeCZ
Another built-in option is hovering over filetabs... with previews and autoactivating off.
RSomppi
