Autocad is super slow when zooming in and out or when switching between model space and paper spaces
peterchanGQ8HU
peterchanGQ8HU
Using Autocad 2023
Already turned on cache viewport and layout.
2D wireframe as the visualdisplay
It takes several minutes to load every time.
Other files ok.
This specific file has 5 xref.
Total file size is 350Kb.
Spec: i9-11900
64 Gb Ram
NVIDIA A4000
paullimapa
Since there are 5 xrefs, the total file size needs to include the file sizes of each xref
Now as a test save a copy of the file and do the following on the copy:
1) unload all xrefs and see if that speedsthings up?
2) unload 1 xref at a time and see if any speed differences as each is unloaded
3) detach 1 xref at a time to see if there are performance differences
Paul Li
IT Specialist
@The Office
pendean
Community Legend
Community Legend
@peterchanGQ8HU wrote:
....This specific file has 5 xref....
Which of your 5-xrefs are huge and slow? OPEN then test each one, you'll find the culprit(s) right away. More tips here
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Improving-performa...
and if the XREFs are clipped...
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Slow-performance-u....
HTH
