AutoCAD in Product Design Suite Ultimate 2016
Message 1 of 13
Just installed Autodesk Product Design Suite Ultimate 2016 and can't open standard AutoCAD. When i go to the program files and open the acad.exe it opens up Mechanical instead. Is there a way to open up standard AutoCAD?
Replies (12)
Message 2 of 13
DarrenP
there should be an Autocad icon under the Autocad Mechanical folder in your start menu
DarrenP
Message 3 of 13
wispoxy
@Anonymous Just change your workspace setting. That's what I do.
Message 4 of 13
Darren,
I attached a screen shot of what was in the folder.  I noticed that it says AutoCAD 2016 English - AutoCAD Mechanical, like its still pointing to Mechanical.
I'm I missing something? Do i have to change a setting?
Thanks for the response.
Message 5 of 13
Here's the screen shot.
Message 6 of 13
Here's another screen shot of the folder structure before entering into AutoCAD Mechanical folder. Its not showing up. Did I do something wrong at time of installation?
Message 7 of 13
JDMather
Expand the AutoCAD Electrical or the AutoCAD Raster Design.
Somewhere in there you should have a link to Run as AutoCAD.
If not, then someone will walk you through creating a desktop icon for starting as vanilla AutoCAD (a search might be faster).
Message 8 of 13
ampster40
the shortcut you show in the 1st screenshot you provided is the correct icon to use to launch just plain AutoCAD. HTH
Message 9 of 13
Do I change the target on the desptop icon to say <<VINALLA>> instead of <<ACADMPP>>?
Message 10 of 13
Nevermind that last email, I got it to work.
Thank you all for your comments and help.
Message 11 of 13
wispoxy
@Anonymous Did you skip my post or something?
Message 12 of 13
I just wanted straight AutoCAD to run. I do have a different workspace already.
Thanks.
Message 13 of 13
ampster40
if they use the shortcut to launch Acad Mech, then it will load...nevermind.
