AUTOCAD HATCH 10' X 4' RUNNING stretcher bond
Message 1 of 20
Hi ALL,
I NEED TO CREATE A HATCH JUST LIKE THE AR-B816 DEFAULT BUT WITH DIFFERENT dimensions
i need 10' x 4'  elevation 18001 PRELIM DESIGN _25 JUNE 18 _MY LOCKER PRELIM (1).jpg
please help??
i attached a picture for the pattern that i want
Replies (19)
Message 2 of 20
Patchy
Open the acad.pat
copy the 8x16 pattern and make a 4x10 or 48x120
Message 3 of 20
i tried but i didn't work for me...
so this is the
*AR-B816, 8x16 Block elevation stretcher bond
0,       0,0,      0,8
90,      0,0,      8,8,
can you do it for me?
Message 4 of 20
Patchy
Message 5 of 20
john.vellek
Hi @Anonymous,
This should give you a 4x10 pattern.  If you are working in inches and have units set to Architectural, you will need to scale this up by a factor of 12.
*4x10, 4x10 Block elevation stretcher bond
0, 0,0, 0,10
90, 0,0, 4,4
John Vellek
Message 6 of 20
Patchy
After adding new pattern, exit autocad and restart to see new pattern.
Message 7 of 20
i did what you post and i got it stacked ?
Message 8 of 20
hi,
ok am getting the right dimension but it stacked?
not running ??
Message 9 of 20
john.vellek
Hi @Anonymous,
Yes, I apologize but I missed that. I am about to run into a meeting but will come back to this shortly for you.
John Vellek
Message 10 of 20
 i got it stacked like this pic! but i need it running? like the first pic i posted
Message 11 of 20
Patchy
My bad,
*AR-BRSTD1, Standard brick elevation stretcher bond
0,       0,0,      0,48
90,      0,0,      48,60,                      48,-48
Message 12 of 20
Kent1Cooper
0,       0,0,      0,8
90,      0,0,      8,8,
You left out the 8,-8 at the end of that second line....
Try this, if your drawing unit is a foot:
0, 0,0 0,4
90, 0,0, 4,5, 4,-4
Or, if it's an inch:
0, 0,0 0,48
[In the latter case, you could also use the first definition at a scale factor of 12.]
Kent Cooper, AIA
Message 13 of 20
ITS NOT WORKING
Message 14 of 20
ITS NOT WORKING 😞
Message 15 of 20
john.vellek
Hi @Anonymous,
Try this and let me know if you are having continued difficulties in getting it to work.
John Vellek
Message 16 of 20
Patchy
I tested and it works
Message 17 of 20
thank you... 🙂
it works
Message 18 of 20
thank you..
it works 🙂
Message 19 of 20
Kent1Cooper
@Anonymous wrote:
ITS NOT WORKING
"Not working" isn't really enough information -- does it draw something but look wrong?  does it not come up as an available pattern?  does trying to use it result in some kind of error message?  etc.  Just to consider some possible reasons [since the content of several proposed definitions is identical to what did work]....
It needs to have a pattern name line [call it what you like, but format the content in the correct way].  And it needs to be either  added into the ACAD.pat file or  it needs to be saved to a file with a .pat filetype ending, with only the one definition in the file, and with the file name preceding that ending identical to the pattern name.  A mismatch there is a common mistake.  Another common mistake is to add it to the end of ACAD.pat but to not have an empty line at the end of the file  [i.e. the file must end with an Enter, not with the last character of the last pattern definition].
Kent Cooper, AIA
Message 20 of 20
hi,
sorry i was at work so my answers were very short,
don't worry the guys here solved the problem!
thanks for your help 🙂
