Editing Text will not display
Message 1 of 20
HI
I Have install CAD in a new system, Its doesn't display any text
I have tried the following steps but still ...
Issue:After opening a drawing in AutoCAD, all the text within it does not display. The text objects are still there and can be selected, but no lettering or other characters is shown.
Solution:Do one or more of the following:
  1. Enter the STYLES command and look through the text styles to see if fonts are missing. Obtain copies of missing fonts and install them into AutoCAD's font folder (C:\Program Files\Autodesk\AutoCAD 20xx\Fonts) or within the operating system. SHX and fonts go into the AutoCAD\Fonts folder and TTF fonts go into the C:\Windows\Fonts folder.
  2. Within the Styles window, turn off "Use Big Font" for affected text styles.
  3. Turn off annotation on the text objects. Use the QSELECT command to select all text and then in Properties, change Annotative to 'No' (see Invisible Text [screencast]).
  4. Add a path to the AutoCAD Fonts folder:
    1. Open Options and click the Files tab.
    2. Under Support File Search Path, add:
      C:\program files\autodesk\autocad 2018\fonts
      Note: Edit this for your version of AutoCAD.
    3. Click OK.
  5. Change the substitute font (see How to specify an alternate font in AutoCAD).
Thank you In advance
M Buthelezi
Replies (19)
Message 2 of 20
pendean
Community Legend
Community Legend
Share with us your DWG file, let's all have a look for ourselves.
Message 3 of 20
Message 4 of 20
pendean
Community Legend
Community Legend
The DWG file you posted has text objects everywhere
Message 5 of 20
user181
Hi @Anonymous,  make sure QTEXT is turned off and/or QTEXTMODE is set to 0
Message 6 of 20
Patchy
Can be:
Annotative Text
Text layer frozen or Off in the viewport
Message 7 of 20
Yes, I checked its 0 not 1
Message 8 of 20
I have checked, also I am not using one layer for text.
@Patchy wrote:
Can be:
Annotative Text
Message 9 of 20
cadffm
@Anonymous
stop your searching and upload the right sample file.
Pipes.7.dwg (omg) works fine for you, or not?
Sebastian
Message 10 of 20
@cadffm wrote:
@Anonymous
No, Its not working by my side, only in this computer.
Message 11 of 20
cadffm
Ok, thats another thing.
Please open my attached file, it open in modelspace..
Without any changes make a Screenshot of the whole program-Window and upload this screenshot please.
Sebastian
Message 12 of 20
Please see attached screen short
Message 13 of 20
cadffm
Thats not your posted file and it is not my posted file,
why do you make finding the solution unnecessarily difficult and time-consuming?
We can only check your uploaded files and we can not know if there is a ifference
between the known file what we have and your displayed/screenshot files
which are important for the issue.
Please:
and is TEXT disappearing in all files or only in some?
Start, a blank new file:
command NEW
user the arrow right of [OPEN] and use "without template - imperial"
Create a new TEXT and MTEXT,
Is it working?
Sebastian
Message 14 of 20
The posted file is the file you send back to me. After I have open it there's no text.
Any file that I am opening its doesn't display text but if I am using other computer its does display text
All text are there but invisible.
Message 15 of 20
I am suspecting workspace setting
Message 16 of 20
cadffm
Please start your Acad in safemode! F1 - command line switch
@Anonymous
Your posted file and my posted file are have different settings and content.
cannonscale = 1:1
CLAYER is  "TEXT"
There is no Layer "Flow Rack" inside the file...
It is not your and my uploaded file.
Sebastian
Message 17 of 20
cadffm
Windows Repair-Install
or
clean uninstall, clean re-install
Before you can export your current settings. - F1
Sebastian
Message 18 of 20
jayhar
Please Try Command  "GRAPHICSCONFIG" and off Hardware Acceleration, Find the attachments
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
Message 19 of 20
Hi Javhar
Yes it's off
But still ...
Thank you
Kind Regards
Buthelezi MM
Message 20 of 20
jayhar
Same problem i have being solve here in my office, All are Autocad LT version are using.
Can you Please upload Cad file.
