Hi Alundy,
I ran a Purge, Audit, -Purge>regapps and finally an Exporttoautocad. This reduced the file size (about 15MB) a bit but you have everything exploded into individual objects.
I guess that all I can suggest is to start moving lines to layers so you can more easily determine what to keep and what to delete. I am guessing that all the wall pattern entities could be erased and would make a significant difference in file size. I would also consider removing all the wall centerlines and the inside face of gwb.
John Vellek
