Solved by john.vellek. Go to Solution.
most common for that situations are:
server is not a Windows server (instead it's a NAS or a network connection to a cloud service) ==> so which type of network do you have
the folder or the network share (you like to save to) has not enough permissions for your account (make sure you can read/write/edit/delete (and execute)
an antivirus filter is catching dwg files
I guess the best is to check this with your network-admin.
Good luck, - alfred -
DO THE FOLLOWING SETTINGS
Hi @Anonymous,
Have you had the chance to look through @Alfred.NESWADBA's excellent suggestions? Here also is an article that details some other factors that might be involved.
