How do i add a layout tab on autocad 2015?
How do i add a layout tab in autocad 2015?
I have tried both ways given to me when i google it by autodesk. It tells me to enter Options in my command box and then to click on the display button but there is no display button. The other option is to type CUI in my command box then in the right click 'properties' but there is no properties options! so now i dont know what to do
user181
If I understand you correctly to create a new layout tab there should be a + symbol next to the layout tabs on the bottom left of the screen. Or you can right click on the Layout1 or any other tab and select the new layout option or the move or copy option.
ennujozlagam
@Anonymous hello, go to options > tick "Display layout and Model tabs" (please see attached). Then the paper space just clik + sign or right click on Layout > New Layout. hope it helps. thanks
Michiel.Valcke
You can also use the _LAYOUT > New command.
