AutoCAD Forum
AUTOCAD FEREEZ ITEMS SHOWING IN PRINTING SHEET
5 REPLIES 5
301 Views, 5 Replies
5 REPLIES 5
When plotting from Auto Cad,  Door Block freeze  in layout but showing in print preview. Please check in picture attachment
nathanhayes98
nathanhayes98
Hi @Anonymous,
Is the item you are trying to freeze in a x-ref?
There might be 2 identical viewports overlapping each other so as you freeze the layer off in one viewport it is still showing in the other. Try dealting the viewport and recreating it to see if the problem occurs.
If your still facing the issue could you send a copy of the file to take a look.
Regards
Nathan
Hi @Anonymous,
Regards
Nathan
chriscowgill7373
chriscowgill7373
Which version of AutoCAD are you using?  2018 had some issues with this, that were resolved with some of the updates that were released.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2022 on Windows 10
in reply to: chriscowgill7373
Auto cad  2017
Auto cad  2017
cadffm
cadffm
Hi cool Nickname,
what kind of objecttype is it?
If nested in Block or xref, open the block(or xref) to check the objecttype.
 Sample file would help us.
Sebastian
Hi cool Nickname,
Sebastian
AutoCAD Inside the Factory
