I get an error when Autocad starting says "AutoCAD exception in acmgd.dll arx command E0434352 (e0434352h) at address 61747788h". And Autocad did not start.
I tried so many things like
No use any of them. Any suggestions.
Solved by Alfred.NESWADBA. Go to Solution.
please let us first know a bit about your environment
- alfred -
Thenks in advence.
neither AutoCAD 2011 nor AutoCAD 2014 are designed to run on Windows 10 (not supported as you can see in the system requirements for them >>>click<<<).
>> It is perfectly fine for years then stop working
Then look to the updates (system updates, graphic card driver updates) or new installed software ... which of them were installed since AutoCAD worked fine previously?
What happens if you uninstall them?
An option might also be to go back to a system restore point.
- alfred -
Thank you very much.
It is very helpful. System restore point solved my problem.
Thanks again.
Hello, the error im getting is "exception in acmgd.dll ARX command - Unhandled exception 1 (e0434352h) at address E5D495FCh"while opening autocad 2016 and the OS im using is windows 8.1. Any feedbacks on how to go about this problem? Thank you in advance.
welcome @Anonymous.autodesk.com!
Some questions:
- alfred -
When i try to open autocad the problem persists and i dont think im using and 3rd party plugins on top of the software. Before, i tried deleting the files in FLEXnet folder and in "C:\Windows\Microsoft.NET\Framework64\v4.0.30319" i couldnt find the file machine.config as per the suggestions above. And im not sure which service pack i am using but i do have the latest windows definitions installed on the system.
>> Before, i tried deleting the files inc [...]
Just deleting files does not solve anything,
As you tried to modify Framework program files and also in AutoCAD folder please
Good luck, - alfred -
Hello, tried each of the suggestions step-by-step but to my dismay the software again showed similar problem. I guess i will have to uninstall it and install some older version of autocadd. Anyway, i ll leave you with a screenshot of the latest error im getting and if there's any solution to it i will be glad to try it out once. And thank you once again for all your time.
sorry to hear that, only a few ideas left:
either update your graphic card driver and/or check the procedure to start AutoCAD without hardware acceleration (>>>more details<<<).
create new Windows user account with admin permissions, login with that account, disconnect your workstation from network, disable antivirus and now start AutoCAD
and at least run a clean uninstall and reinstall (>>>click<<<)
