- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
This is an error previously posted but nothing seems to fix it and unlike the others this is drawing specific (see below attached dwg where 1.dwg is -exporttoAutoCAD and then _CL.dwg is the original). I am going through some of our old blocks and all of them in this one file seem to return this error no matter what I try. My Printer Support file directories are the same for all the other files that work fine. I open these in 2019 or 2021 and it does it. If I copy linework to another file that does not do it and then save that file it will then do it when I open that file.
The only thing that fixes it is if I change the printer from None to one of our printers. But then if I -exporttoAutocad or anything where the print gets reset to None then it will do it again. But all of my other files that that default to None do not do this. IT is only the blocks in this one folder.
Thank you
