I have combed and combed for an answer but they all say the same thing and it does not fix it. They also all seem to be from 2012 or earlier.
Can someone tell me why the default 1:1 scale in this template will not delete? This template is simply a 2021 acad.dwt template with scale 1" = 1' added, layouts deleted, units changed, and annotation styles deleted. This is just a bare bones template to start from in cleaning up some blocks.
What I have done that I have found online. Checked all styles and none are set to annotative. Changed model space to 1" = 1'. In layout the properties window has the 1:1 annotation scale greyed out. The only way to fix this was to create a viewport, select viewport, and change viewport annotation and standard annotation to 1" = 1'. Then the greyed out scale says 1" = 1'. Which another weird thing is the Standard annotation in the viewport would not stay changed from 1:1 until I moved 1:1 below 1" = 1' in the annotation list. But if I delete the layout and CAD creates a new one then the 1:1 greyed out scale is back.
I need this gone in some other templates, but out of curiosity do annotation scales follow blocks when you insert them into drawings?
Thank you
