autocad does not recognize mapiinsert
yairMSKTU
Message 1 of 11
yairMSKTU
autocad doesnt recognize the command mapiinsert.
how to fix it ?  i REALLY need it.
thanks.
*what commands adds ADIMENU tool ?     i had it before and it disappeared.
Replies (10)
Message 2 of 11
vinodkl
Hi @yairMSKTU
MAPIINSERT command is not available in Plain AutoCAD. If you are talking about AutoCAD MAP 3D, then check this link:
https://forums.autodesk.com/t5/autocad-map-3d-forum/mapiinsert-command-problem/td-p/8250296
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 3 of 11
yairMSKTU
Message 4 of 11
lots of info on how the specialized toolsets work just look
like this:
https://knowledge.autodesk.com/support/autocad/getting-started/caas/simplecontent/content/autocad-sp...
Message 5 of 11
Pointdump
Hi @yairMSKTU,
Welcome to the Autodesk Forums.
"autocad doesnt recognize the command mapiinsert."
Do you have Vanilla AutoCAD or Map 3D or Civil 3D? As @vinodkl says, that command is only in Civil 3D or Map 3D.
"it says it is already included."
That link says you have to download it, and I think they are referring to Map 3D.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Message 6 of 11
pendean
Community Legend
Community Legend
Pay attention: "toolsets" is bad wording from Autodesk, those "toolsets" are totally separate programs you must download and install. In your case, that would actually be AutoCAD MAP3D.
Plain AutoCAD does NOT and never will contain all variants in the one single program..
Now you know. Now you can go get and install AutoCADMAP3D, its free with your current subscription.
Message 7 of 11
yairMSKTU
thanks.
now all i need to do is get the IT department ...
Message 8 of 11
Pointdump
Dean,
"...problems you must download..."
OK, that's funny!
Dave
Dave Stoll
Las Vegas, Nevada
Message 9 of 11
pendean
Community Legend
Community Legend
Message 10 of 11
yairMSKTU
finally IT came but they told me they cant install map 3d because i dont have civil.
is it true ?  is it impossible to install it with my license because i dont have civil ?
Message 11 of 11
Pointdump
@yairMSKTU,
Civil 3D is built on top of Map 3D, so if you have Civil 3D then all the Map Commands work.
Dave
Dave Stoll
Las Vegas, Nevada
