Mapiinsert Command problem
Message 1 of 10
I'm running Map 3D 2015, use MAPIINSERT daily. Recently the command refuses to show the window
that first comes up where you designate the scale, placement coords... instantly inserts everything, (rasters or blocks)
at 0,0.  I have to zoom out, select the inserted object, drag it to my location and scale it up. Not sure where
the initial window in the command disappeared to.  Did a variable possibly get changed?
Appreciate any suggestions.
TR
Replies (9)
Message 2 of 10
Alfred.NESWADBA
try to set these system variables:
FILEDIA ==> 1
CMDDIA ==> 1
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 10
АлексЮстасу
Perhaps you need to enable the Modify Correlation option.
-- Alexander, private person, pacifist, english only with translator 🙂 --
Object-modeling _ odclass-odedit.com _ Help
Message 4 of 10
ChicagoLooper
You must be executing a command for an image to be inserted at 0,0. Do you remember the command?
How does Map3D know to insert that particular image as opposed to another one? What instigates Map to go to that specific folder and pick out that specific image? Why not another image in the same folder? Why doesn't it go to a different folder on a different drive? Perhaps you are leaving something out? Maybe something vital that may hold the key to resolving your issue.
Chicagolooper
Message 5 of 10
Alfred.NESWADBA
good catch, and I want to add: maybe the files don't have a geo-position information (world file or geo-position info in header).
- alfred -
Alfred NESWADBA
Message 6 of 10
"Modify Correlation" clicked ON did the trick. Again, Thank you!!
Message 7 of 10
Thank you, sir. Problem solved.
Message 8 of 10
АлексЮстасу
Thank you!
Just in case!
If you need to insert already georeferenced images, then it is very desirable to disable the Modify correlation option. With the Modify correlation enabled, some incomprehensible coordinate recalculation can occur, and images can be inserted slightly shifted.
Message 9 of 10
Sharif.MashahidG2UDG
You made my day! Thanks
Worked perfectly
Message 10 of 10
svarshn1
Community Visitor
Community Visitor
Worked out. Thank you!
