Hi Guys,
Just want to know, if there is any chance autocad can show a reminder when dimension overlap, when I have many dimensions and If I make an error - one dimension overlap on other, it is really hard to see when doing a big project with many dimensions unless you go over to check every single dimension. For example as shown, the room size only 910, but sometimes when people make an error it become 1000, it is really hard to find out this kind of error unless you check them carefully on every single dimension, it would be good if someone can tell me how to make a reminder these dimensions are overlaping.
Solved by ВeekeeCZ. Go to Solution.
>> it is really hard to find out this kind of error unless you check them carefully on every single dimension <<
i'm afraid that this is the fact ... AutoCAD will give dimensions that were you pick your points and select . matching inner and outer dimensions ( as your case ) not available since users are responsible for that .
Imad Habash
