AutoCAD Crashing
AutoCAD Crashing
wvakala
AutoCAD Crashing
wvakala
Hi there. I exported a road design, multiple section views to be specific to AutoCad so that I can do some few edits in preparation for submitting the drawings. However, in the exported drawing, whenever I try selecting a text to edit or move, the drawing freezes for a very long time and eventually crashes. This has happened repeatedly and as such haven't been able to work on the drawing at all. Please assist on how to fix or prevent this. Thank you.
ennujozlagam
hello, try to install latest updates from autodesk and see if helps. thanks
Joe.Gio
Try typing in 'Audit' and 'Y' to see if that cleans up the drawings for you. Then 'Purge' and 'purge all'. You may have to purge all 2 or 3 times. This should clean up the drawing and hopefully fix with your error.
wvakala
Hi Joe
Thank you for the suggested solution. Unfortunately, this has not worked at all. Any other solutions that you can think of please will be highly appreciated.
