Hi all,
here is the First script with Autocad core engine console to convert the CAD file From *.dwg to *.dxf
its having two part
both sample files are available in zip folder just change the path as per your AutoCAD Version and File Folder
also i am planning to put Script for plotting on next week
Small Video Link : - https://youtu.be/HenmmFvykd0
hope everyone like this also do support my Youtube channel
Thanks and Regards,
Hari Nair [Master From Lost Nalanda]
Hi all,
here is the Second script with Autocad core engine console to Plot Cad to PDF (Model Format)
its having three part
sample files are available in zip folder [Plot A1] just change the path as per your AutoCAD Version and File Folder
Small Video Link : - https://www.youtube.com/watch?v=vrLA6qhJ1mc&t=15s
Thanks and Regards,
Thank for the input, it was helpful
I got it to work but, I not sure how to get to plot to a folder other than the source foler
Here is what I have.
echo off
"C:\Program Files\AutoCAD 2000\acad.exe" /p "K:\AutoCad\Support_Client_Files\client\Profile\Client2018.arg
:: Path to AutoCAD core console
set accoreexe="C:\Program Files\Autodesk\AutoCAD 2018\accoreconsole.exe"
:: Path the directory to process
set "source=C:\CADDLib\AutoCAD\Projects\######"
:: Path to the script to run
set script="C:\CADDLib\AutoCAD\Projects\######\printsheet.scr"
FOR /f "delims=" %%f IN ('dir /b "%source%\*.dwg"') DO %accoreexe% /i "%source%\%%f" /s %script%
