AutoCAD - Can i batch plot multiple views of a 3D object to a pdf file?
Lukas.StoltzAndersen
Observer Observer
Observer
Observer
I am trying to convert a 3D dwg file to a PDF.
I dont want a 3D PDF, but a normal PDF file, containing several angleshots of the original 3D dwg file.
This could for example be a shot from the top, bottom and side of the dwg file.
Is there any way to do this in a batch? im looking to convert around 5000 dwg files.
Thanks in advance
[ The subject line of this post has been edited for clarity by @handjonathan Original:  Print 3D .dwg file from multiple angles to 2D PDF file ]
ennujozlagam
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-p...
Observer
Observer
Thank you for the reply
Maybe i should be more elaborate.
Lets say i wanted to print a 3D figure of a human. I would like to print a view of the frontside of the human, the backside of the human, and a top-view. Is this possible to do automatically, og do i need to make 3 different layouts, with each their own view manually?
handjonathan
Hi @Lukas.StoltzAndersen
Maybe using the VIEWBASE command may give you the result you require. A base view is the first view created in a drawing and then all other views are derived from the base view.
Jonathan Hand
Technical Marketing Manager | Construction
