Autocad Block Transfer Drawing for drawing with all characteristics.
I want to pass the blocks with all their characteristics.
Includes editing.
Best regards
Hi @Anonymous,
I believe the feature you are looking for is eTransmit. This feature will let you bundle drawings and the required fonts, xrefs, plot styles, etc. It will put all of the data into a ZIP file for archive or for transmitting to others.
Thank you
I mean I created a block, edited it by filling in new data every time.
How to copy the block completely.
Thanks in advance
Hi @Anonymous,
Can you attach your block to a post? Or the drawing that contains it? I would like to see how it is made and what you are editing. If the parts you edit are part of the block then you should be able to use WBLOCK to create a block that can be inserted into other drawing files.
