AutoCAD Block Attributes: Annotative Behaviour
Jake_PCH
Message 1 of 13
Jake_PCH
I have set the different block attributes within the attached block to different annotative displays. This works within the block but not once the block is placed - once placed ALL attributes show regardless of their respective annotative scale setting within block.
Is this a limitation of block attributes or am I missing something?
Replies (12)
Message 2 of 13
imadHabash
Would you please show us an image for that?
Imad Habash
Message 3 of 13
TheCADnoob
what is your ANNOALLVISIBLE  varible set to?
https://help.autodesk.com/view/ACD/2024/ENU/?guid=GUID-D8E50F6F-FB71-4A20-A3B9-7701C0518B81
ANNOALLVISIBLE (System Variable)
Hides or displays annotative objects that do not support the current annotation scale.
Type: Integer
Saved in: Drawing
Initial value: 1
Value
Description
0
Only annotative objects that support the current annotation scale are displayed
1
All annotative objects are displayed
The ANNOALLVISIBLE setting is saved individually for model space and each layout.
Note: When ANNOALLVISIBLE is set to 1, annotative objects that support more than one scale will only display one scale representation.
CADnoob
Message 4 of 13
imadHabash
just guessing...
You may need to change ANNOALLVISIBLE value.
Command: ANNOALLVISIBLE
Enter new value for ANNOALLVISIBLE <0>: 1
Imad Habash
Message 5 of 13
Jake_PCH
Thanks for the responses. I can confirm ANNOALLVISIBLE is not the issue. See screen recording...
Message 6 of 13
cadffm
You can nor pre-define or pre-set the attributes in future.
It works with layer, color and default value, but there is no default annotation-scale.
Sebastian
Message 7 of 13
Jake_PCH
Hi Sebastian,
Could you please expand upon your comments?
Message 8 of 13
cadffm
Sorry.
What I said is: It is not possible this way.
You can not pre-set all (wanted) scales.
Your block working well, but it is not possible to create a new blockreference
and the created attributes already has the scales you want.
Workaround, rarely one you are happy with:
If you want to create a new blockreference with attributes, what have pre-set scales,
you need to copy an existing blockreference,
with attributes, what have the scales in question.
Sebastian
Message 9 of 13
Jake_PCH
Thank you for elaborating. Could you please clarify what you mean by blockreference?
Message 10 of 13
cadffm
Blockreference is the object what is displaying your block.
Take a random DWG and select "one block" by mouse pick and
take a look to the properties [CTRL+1].
On top this palette, you will see the object type. THIS is a BlockREFERENCE!
Blockreferences displaying the BLOCK CONTENT (line circles and so on).
Blockreferences are NOT copies of " a block"
Sebastian
Message 11 of 13
Jake_PCH
Thank you for clarifying.
So, unless I'm mistaken, I am already using your approach. Even when I insert the block as new (not copy), the attributes of the blockreference do not behave in the same way as they do within the block environment.
Message 12 of 13
cadffm
Right, because your Attributes (what are attached on a Blockreference) are independing copies of your AttributDEFINITION,
and AutoCAD forget (= not designed to) to add the supported scales from your Attributdefiniton(ATTDEF).
Take a look:
Select an Attrib! How to: Press and hold CTRL while you pick on an attribut.
Take a look to the properties.
It is annotative, yes, but look at the supported scales (in Properties palette, click on the current scale - f.e. 1:1
right of this value, press [...]
You will see, just one scale is listed.
Add more scales to check if it works then.
You can copy this blockreference and it will work fine too.
All you can learn from this: Autocad is not designed to work as you want (the blockreference creation process).
Sebastian
Message 13 of 13
Jake_PCH
Thanks for clarifying again.
A function to retain attribute properties (NOT content, ie. Text/Field value) would be a good feature for Autodesk to add!
