Only map 3d opens even if i click autocad architecture! Disc C only contains one autocad folder with no specification, did autocad architecture get overwritten by map 3d? Is there any way to work with both?
Solved by pendean. Go to Solution.
I'm using the shortcuts in windows start menu. Both autocad architecture and autocad map 3d link to acad.exe, and i only have one autocad folder installed (C:\Program Files\Autodesk\AutoCAD 2015). I do not have separate folders for map 3d and architecture. I always let autodesk installers run automatically without editing any settings.
I did exactly as you said though. The path in properties says "C:\Program Files\Autodesk\AutoCAD 2015\acad.exe" I only have one computer and both programs were installed on it. When i click either of the shortcuts (both of which lead to the same acad.exe file) Autocad map 3d opens. I have no idea why is it this way, but it started after i installed autocad map 3d today. There is no other exe to start and i have no idea how to get back to autocad architecture.
