AutoCAD Forum
AutoCAD Arch 2025 Meters
1 REPLY 1
wapoolverlop
84 Views, 1 Reply
I’m using 2025 Arch where in unit setup you can spec units as millimeters or meters rather than the old decimal method.
When drawing in meters and setting up the units in page setup, I used to spec 1mm = .001 units.
Now when drawing in meters, in page setup I have to set 1mm = 1 unit in order for the viewport scales to work out.
Is there something I’m missing here?
1 REPLY 1
You're printing in Paperspace?
AutoCAD Inside the Factory
