Trim 3D polyline on a surface
berny1504
Observer Observer
berny1504
Observer
Observer
I need help with this problem:
I have a big XYZ file (3D points) imported in autocad. I have to draw some simple 3D object on the surface generated by these points. The points descrive a regular non planar surface.
I have to cut the 3D object in such a way that it stops in correspondance of the surface and then export the modified surface again in points like file (the XYZ is the imput file of another program).
I have tried to draw the 3D object with 3Dpoly and to build the surface under it with loft function, but i don't know how to trim it.
I'm not confident with Autocad3D, can you please give me some suggestion?
Thank you
TomBeauford
Calculating volumes from surfaces like that is fairly simple with Civil 3D. I'd question the accuracy doing it any other way.
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
berny1504
Observer
Observer
Con you please give me an idea of the command I should use to interpolate the surface in civil 3D, trim them and extract XYZ points so I can study and try them. Maybe I can download civil 3d with the
university license, but I have never used it and have no idea on how to work with it.
Thank you
TomBeauford
Online search for civil 3d volume calculation returns many options but Calculating Volumes With the Volumes Dashboard is what I would use for what you described.
For capacity of a stormwater area I'd determine the overflow elevation and add a contour at that elevation, then extract it to the drawing as a boundary to use with the Volumes Dashboard to get a quick accurate volume.
2023
