AutoCAD Admin Rights to make changes when opening
bbrooker15
bbrooker15
When I try to open AutoCad or Architecture in a non-admin user account, I get this message:
When I enter the UN & PW, it goes ahead and opens after some configuring. When I click no, it shows this message:
I'm not trying to remove the application. Anyone know what is going on? Thanks.
AllenJessup
This may mostly be a Windows issue. See if anything HERE helps.
THIS seems to address your issue directly.
Allen Jessup
CAD Manager - Designer
paullimapa
If you want to uninstall AutoCAD 2026, follow the instructions here:
https://www.autodesk.com/support/download-install/individuals/manage/uninstall-autodesk-software
Paul Li
IT Specialist
@The Office
bbrooker15
Running the script to add the registry key worked. Thank you very much!
bbrooker15
Thanks for responding. I was able to get it to work with the link from the previous post. By the way, the link you sent said access denied.
paullimapa
Odd...something is definitely going on with your Windows OS or perhaps you're running an antivirus program that's detecting false positives.
The link goes to an Autodesk page that looks like this:
Paul Li
IT Specialist
@The Office
bbrooker15
It works. It was due to the device I was on. Thanks.
