I am running XP as my OS and My AutoCAD is 2008 version. I am having bunch of problems specifically with Microsoft outlook. My question is if I upgrade my OS to latest Microsoft OS which are all 64 bits program. I have to buy recent version of AutoCAD which is also 64 bit. Will I be able to open archived drawings of past projects created with 32 Bit version of AutoCAD if I upgrade to newest Microsoft OS? Are the latest versions of AutoCAD backward compatible?
Solved by braudpat. Go to Solution.
Dean:
What do you mean by "Full Admin" I have original CD which is upgrade from LT with necessary Keys. Will that suffice to install on OS 7?
Hello from France
+1 with pendean
Win Seven is officially supported by Autodesk with the ACAD 2011 but everybody knows that the 2010 is running fine with Win Seven
With releases 2009/2008 (not at all supported) you can install and you can (I say "CAN") run on Win Seven (without major problems)
ONLY if you are Full Admin (Windows Login) of you PC when you install (NORMAL) and when you run the software ...
... Sometimes it's OK / Sometimes NOT ...
Patrice BRAUD
