>> Alfred please answer to my questions,
I tried
>> Is Autodesk able to make ONE software to draw and to model?
Maybe we need to discuss the wording, but yes, Autodesk has products to draw and to model, e.g. AutoCAD, Inventor, Revit, Fusion, ...
>> Or does Autodesk prefer to divide different tools in different software
>> just to sell different licences?
Each software has it's strength, pros and contras, however, you are referring to a product that is not from Autodesk and you want to use AutoCAD as well as TwinMotion, I don't see where you have to buy now anything else if you want to use these 2 products.
>> If not, please stop to defend a software that, in my opinion, is far away the potential of ArchiCad
If you compare AutoCAD (a generic CAD product without any vertical/branch orientation) with ArchiCAD (which is built for Architecture usage) then you are comparing different product types. You should then compare Revit with ArchiCAD instead of AutoCAD and ArchiCAD.
You may use AutoCAD Architecture (which is in the same license model as AutoCAD), which is AutoCAD + architectural add on's and exchange formats.
>> that allows everyone to draw in 2d, modelling in 3d and export in several formats
Same as AutoCAD and Revit can, however AutoCAD as generic CAD program uses generic exchange formats, while Revit (as well as ArchiCAD) can export specific files for architectural interchange like IFC.
>> using direct link to several render softwares
Same here: Revit has a direct link to TwinMotion, but not AutoCAD.
Maybe the decision to use AutoCAD instead of Revit (which seems to fit better to your needs) was incorrect?
To be honest, I don't defend AutoCAD, I just answered to the question exchanging data from AutoCAD to TwinMotion .. this was your question.
If you now see that AutoCAD does not fit your needs (seeing that you compare it with ArchiCAD) and therefor see my replies as wrong .. then sorry.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ...
blog.ish-solutions.at ...
LinkedIn ...
CDay 2026------------------------------------------------------------------------------------
(not an Autodesk consultant)
