I recently upgraded to AutoCAD 2025, and I'm seeing a new issue that's been popping up in my drawings lately. On polylines, when in a command like fillet, or move or copy, I can grab segment end grips, but not midpoints on some segments on polylines in my drawings. Seems like I can see and select midpoint grips on arc segments, but often cannot on line segments. If I select the polyline outside of a command, I can see the midpoint grips and grab them, I just can't seem to do it inside of another command randomly. These are not complex shapes with hundreds or thousands of segments either, but often very simple shapes as in my latest case, which is under 30 segments.
Here's what I've checked so far:
2D OSNAPS are set to have midpoint active and 3DOSNAPS are all disabled except for center of face, turning on midpoint of edge doesn't make a difference. I have checked the GRIPS System Variable, it is set to "2" since it's acting as if it's set to "1". I have also checked GRIPOBJLIMIT it is set for the maximum 32,767.
What should I look at next? This was never an issue in 2024 or previous versions.
Solved by pendean. Go to Solution.
share your sample .dwg
What you can check on your side:
Is the pline far away from wcs 0,0,0 ?
Try this:
MOVE <selectyourpline> basepoint: on the pline targetpoint:
*0,0,0
Does it work now?
Sebastian
You can see, although my screenshots aren't the best, that hovering my cursor over a line segment in the the polyline shows the endpoints only, no midpoint. This object is small, but this has occurred on larger objects too. I have attached the Red object in a DWG on its own below, it does still occur in its own purged drawing file which suggests there's a system variable that isn't set right maybe? The grip is there outside of a command, and I can grab it, but in the case of the shown screenshots, I started the MOCORO command and was attempting to set my basepoint as the midpoint of the line segment. Creating a block of this polyline, then opening the block editor and manipulating it inside seems to work as normal, but when in modelspace, the issue persists. Also as suggested, I did try moving the object to the 0,0,0 origin to see if it made a difference, there was no change, and the current instance exists in my model only 81' or so southeast of 0,0,0 so not a great distance away.
Well that's interesting... Yes that works, however since when have polylines had snaps disabled when visual style other than 2D wireframe is selected? I've seen snaps disappear only when working with very complex shapes before, not because of visual styles. Accepting as the solution because it does work, thank you, but I'm not convinced that's the full answer
@gmaine5Q4K6 wrote:... I'm not convinced that's the full answer
You are welcome to try your file in AutoCAD 2024 and older, your stated issue above is the same as in AutoCAD2025, as is the solution. I tested your DWG file in AutoCAD2025-2024-2023 here, I don't have anything older to explore there.
Since I only have access to this file and not the others you are discussing, I have not ability to validate your statements. Perhaps others want to offer an opinion on your additional items.
