Hello Autodesk community, I have recently tried AutoCAD 2025 and found out that it is not possible to use ALT + TAB to switch between open drawings anymore. This is an essential part of my workflow to the point where I prefer to stick with the previous version to preserve this functionality. I am wondering if this change was done on purpose, and if there's any way to get around it. I have also attached screenshots which demonstrate the old and current behavior. Thank you very much for your time!
P.S: I am aware of CTRL + TAB, however it switches between the current drawing and the drawing that comes after in the File Tab, not the drawing I was viewing prior to the current one. I am also aware of setting SDI to 1, which opens each drawing in a separate window, however this is a legacy command and significantly increase the time it takes for a drawing to open, disables the file tab and interferes with the Publish command.
Alt+Tab is a standard Windows keyboard combination since ver 2 to switch between opened applications. So it was never used by AutoCAD to toggle between opened dwgs within its program window. Perhaps you are running some other customization that caused something similar to occur in previous AutoCAD versions ?
Hello Paul, thank you for looking into this issue. I am almost certain that the behavior is associated with vanilla AutoCAD, since I have verified that both the new and old behaviors occur on different systems and Windows versions. Additionally, it used to be possible to prevent/allow ALT+TAB from switching between drawings by altering the TASKBAR system variable, as documented in the following help article (please note that TASKBAR 0 and 1 do not have an effect on ALT TAB in AutoCAD 2025) https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/ALT-TAB-to-switch-...
I'm able to repeat your issue on my system as well. Time to contact Autodesk:
Thank you for taking the time to verify this issue, I will proceed to contact support, hope this wasn't an intentional change as i'm really interested in the new smart blocks features and this is the only issue preventing me from upgrading.
Does Ctrl+Tab Switch to next Drawing & Ctrl+Shift+Tab Switch to previous drawing as described at:
https://www.autodesk.com/shortcuts/autocad ?
The keyboard shortcut Alt + Tab switches between open windows or applications on a computer without using the mouse. It's been a feature of Microsoft Windows since Windows 2.0 and is also available on macOS.
The AutoCAD 2016 version only had two Alt+ shortcuts by default ALT+F8 & ALT+F11. More recent versions also have one for ALT+F4.
Maybe you're using a newer version or update of Windows (Alt + Tab - Switch between open apps while pressing Tab multiple times.) which controls most keyboard shortcuts.
>>" (Alt + Tab - Switch between open apps while pressing Tab multiple times.) "
Right,
But a simple [ALT]+[TAB] AND RELEASE switchs back to the last used window,
so you can toggle between drawing1 and drawing2 (if drawing2 was the previous active window),
doesn't matter howe many windows/programs are open.
Sebastian
Exactly! This used to be the case prior to AutoCAD 2025, now all drawings are combined under one window in the ALT + TAB switcher, which wasn't the case for at least the 3 previous years.
Retired without access to AutoCAD anymore but I added "Switch Windows" to my "Quick Access Toolbar" many years ago as a much better option. By default it's on the "Interface" panel of the "View" tab in the Ribbon.
Without using any screen space all open drawings with their full paths shown are always available to set current as a drop-down selection. When you have multiple versions with the same drawing name in different folders it makes switching to the right one simple. Screen space matters!
