AutoCAD 2023 - Moving floating window back to file tab
jjmill1
Message 1 of 13
jjmill1
I can't drag the floating window back to the file tab.  I am using Autocad 2023, on windows 11.
I can make them float, but when I want to move them back, I have to other click, and pick move to file tab.
It's not a big deal, just would like to know how to drag back. My sysfloating is set at (0). I set the variable to (1) and it floats immediatley, but still have to other click to move back to the file tab.
[ The subject line of this post has been edited for clarity by @handjonathan Original: Moving floating window back to file tab ]
Replies (12)
Message 2 of 13
pendean
Community Legend
Community Legend
Floating window? Do you mean the commandline? floating panel that got pulled off the Ribbon?
Something else?
Share a screenshot(s) of that if you can, but also one of your ABOUT command pop-up too please.
Confirm your LOCKUI variable setting too please.
Message 3 of 13
jjmill1
I mean floating drawing.
trying to drag it back on to the file tab, so it's not floating anymore.
Message 4 of 13
jjmill1
Sorry I missed this.  My LOCKUI setting is (0)
Message 5 of 13
pendean
Community Legend
Community Legend
Right-click here to do what you want
Message 6 of 13
jjmill1
Thank You. I do that now, but I would like to be able to drag it back.
Message 7 of 13
paullimapa
this is odd...are you running the latest AutoCAD 2023?
Though I'm on Win 10, with LOCKUI at 0, I'm able to grab the title bar of the floating dwg window, drag & drop it over the top of the AutoCAD app where the + tab is and automatically a blue tab appears snapping it back:
Paul Li
IT Specialist
@The Office
Message 8 of 13
pendean
Community Legend
Community Legend
Drag/Drop works fine here all day long in AutOCAD2023.1.2 too
ABOUT command says what about your 2023 version? Perhaps its a Win11 issue, we don't have that in our offices.
Message 9 of 13
jjmill1
Product Version: T.161.0.0 AutoCAD 2023.1.2
Message 10 of 13
pendean
Community Legend
Community Legend
Thanks for the info.
A quick ask around the office and no one here using 2023 is facing your issue at all. Sorry. I suspect your next step will need to be to open a support case with Autodesk if you are on subscription to seek out Autodesk Support's help: https://knowledge.autodesk.com/customer-service/account-management/users-software/support-options/we...
HTH
Message 11 of 13
paullimapa
If this minor missing feature is bothering you that much though everything else is working then you may want to try uninstalling and then reinstalling. But my thought is to just leave it alone.
Paul Li
IT Specialist
@The Office
Message 12 of 13
jjmill1
I guess you didn't read were I said "it's not a big deal"  It's sure not worth uninstalling and reinstalling. Thank you for your advice.
Message 13 of 13
paullimapa
Then case closed.
Paul Li
IT Specialist
@The Office
