Autocad 2023 issue, Unhandlded Exception
andre.micka
andre.micka
I have an issue with Autocad 2023.1.2
I have this error taht appears when I open a dwg or create one.
I can't find the solution of my problem.
It is a new pc on Windows 11. All drivers are updated (chipset, bios, gpu, windows update).
I tried to uninstall and reinstall Autocad, Always the same. I don't have error message with Civil 3D 2023.
Is there someone with this problem solved ?
pendean
Community Legend
Community Legend
Have you installed the 2023.1.2 Update yet? ABOUT command will confirm what you have installed. If not, get it from your Autodesk Account Page here https://manage.autodesk.com/cep/#products-services/updates
Restart your PC afterwards.
If that did not help... Set GFXDX12 variable to 0 (that's a zero) then restart AutoCAD.
HTH
rainer.detemple
I am having the exact same problem, and I have narrowed it down to civil3d datalinks in the drawing causing the error.
In case anyone else is having the issue - I was able to fix it by installing the latest update of the Civil3d Object Enabler.
andre.micka
I still have thé issue...
andre.micka
Thank you,
this is the way !
